Strahan201
Oct 09, 2022Aspirant
Main unit is secured, but satellite is not
Hello. Title pretty much says it all. I noticed today that I have two SSIDs showing; they are both the same name, but one is secured and the other is not. I saw a thread on here for a similar issu...
Oct 13, 2022Guru - Experienced User
Any progress on this?
Strahan201 wrote:
Hello. Title pretty much says it all. I noticed today that I have two SSIDs showing; they are both the same name, but one is secured and the other is not. I saw a thread on here for a similar issue, and the marked fix was to do a firmware update. So I went to the Orbi management site, and sure enough there was a new firmware available. Easy fix, I assumed. Alas, after updating the firmware to V4.6.9.11_2.3.5 and rebooting, same problem. I thought maybe it's a guest network, but nope, that is not enabled.
Any ideas what I can do to fix this?
It's an RBR750 with RBS750 satellite. Thanks!
