Strahan201
Oct 09, 2022Aspirant
Main unit is secured, but satellite is not
Hello. Title pretty much says it all. I noticed today that I have two SSIDs showing; they are both the same name, but one is secured and the other is not. I saw a thread on here for a similar issu...
Strahan201
Oct 15, 2022Aspirant
iyang wrote:
Hi Strahan201 ,
Can we know what's SSID and password ?
What's security mode do you use ?
Thanks.
Sure, it's "Seireitei". Security is WPA2-PSK [AES].
Oct 16, 2022Guru - Experienced User
Can you post a screen capture of the RBS web page using a PC and web browser connected to the RBS web page. This will show if the RBS is correctly secured to the RBR.
Please don't post passwords used on your system in public forums for security reasons. IF a moderator asks about a password, you can send them a private message.
- Strahan201Oct 20, 2022Aspirant
FURRYe38 wrote:Can you post a screen capture of the RBS web page using a PC and web browser connected to the RBS web page. This will show if the RBS is correctly secured to the RBR.
Sure:
Yea, I thought the request for wifi creds was a little odd, but then I figured if someone really wants to spend the time to try to track my neighborhood down and fly out here so they can leech off my wifi, well, more power to em lol
