sslotnick
Jul 20, 2024Aspirant
Main WiFi on RBR750 Network Keeps Dropping
I have an Orbi RBR750 with 2 satellites. I have a main network and a guest network setup. All devices on my network connect and remain connected to the main network except my Lenovo PC. The WiFi icon...
- Jul 22, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 20, 2024Guru - Experienced User
Does this happen with all RBS turned OFF temporarilly?
What channels are set on the Orbi system?
What WiFi Security mode are you using on the Orbi system? WPA2 only or Mixed WPA2 and WPA3? Some older WiFi devices don't support WPA3 Or mixed modes.
What is the brand and model# of the wifi adapter in this PC?
Make sure the drivers for the wifi adapters in this PC are up to date from it's Mfr.
Make contact with the Mfr of this PC regarding help and information for there PC product.
sslotnick
Jul 21, 2024Aspirant
Thank you for your suggestion and comments. I tried all configurations and found that by switching to WPA3, it solved the issue! I appreciate your help!
- FURRYe38Jul 22, 2024Guru - Experienced User
Enjoy. 📡
