dglsmcd_USMC
May 29, 2020Luminary
Manual Download for RBK852/850 Firmware V3.2.15.25 Now Available
Manual download from the NG download website is now available with release notes. If you do the manual firmware update please update your satellite (RBS) FIRST then the RBR. New Features and Enhance...
May 30, 2020Guru - Experienced User
George63 wrote:Junk firmware!
1. Telnet is gone! (no option to activate it under ip/debug.html) Wasn't included from the start.
2. Logging issue still present (incomplete logs sent by e-mail, no DDOS activity logged etc). We notified NG about logging issues seen.3. No option to disable daisy chain Wasn't included from the start. It all automatic on Orbi AX.
4. No option to separate 2.4Ghz from 5Ghz (or to disable one of them) Orbi systems don't support separation of SSIDs. I've asked about disabling of the SSID broadcasts be added on Orbi AX.
5. No option on GUI to see signal strength (in dbm or lines) of devices attached to RBR850 / RBS850. Orbi systems don't support this.
6. Device list on RBS850 GUI is not showing names of devices attached
My RBS shows connected devices and names:
George63
May 30, 2020Tutor
1. wrong! telnet option was included (orbilogin.com/debug.htm)... with this new firmware this option is gone
2. .... maybe next year the log will be fixed.....
3. "the automation" of daisy chain sux... some of us need the option to disable it!
4. lots of people are asking for bands segregation... it worked very well on RBR50 and SRR60
5. Orbi has a signal strength measurement displayed on Orbi App (android and ios)... Why NG is not implementing this on GUI?
6. CORRECTION: Almost all devices attached to RBS850 are displayed as “unknown” and by looking at your screenshot I can tell that you have the same problem. On RBR850 the names of devices are displayed as I named them
