donawalt
Feb 13, 2024Hero - Experienced User
Manual IP address assignment fails, DHCP does not??
Today I disabled IPv6 on my Netgear Orbi 960 router as a test, as the router was using more memory than normal - and it appeared that IPv6 was the culprit. I am testing that to see if memory usage st...
- Feb 14, 2024
When you set up Static IPs on these devices, are you also inputting DNS addresses as well? If so what DNS addresses are you using?
CrimpOn
Feb 13, 2024Guru - Experienced User
manual IP address as in the IP address is set on the device (what is often called a Static IP address), rather than being entered into the LAN Setup as an assignment based on MAC address?
Very odd that something would work for months and then quit working. Especially since IPv4 addressing has nothing in common with IPv6. There were no static IPv6 addresses on those devices, correct?
- donawaltFeb 13, 2024Hero - Experienced User
I set the manual IP address on the device. They showed up in Attached Devices list on the RBR web page. I set them outside the DHCP range of the router, so it did not manage them at all. Very odd.
