donawalt
Feb 13, 2024Hero - Experienced User
Manual IP address assignment fails, DHCP does not??
Today I disabled IPv6 on my Netgear Orbi 960 router as a test, as the router was using more memory than normal - and it appeared that IPv6 was the culprit. I am testing that to see if memory usage st...
- Feb 14, 2024
When you set up Static IPs on these devices, are you also inputting DNS addresses as well? If so what DNS addresses are you using?
donawalt
I set the manual IP address on the device. They showed up in Attached Devices list on the RBR web page. I set them outside the DHCP range of the router, so it did not manage them at all. Very odd.
CrimpOn
Feb 13, 2024Guru - Experienced User
Would be interesting if these specific Apple devices updated software about this time.
This is truly a mystery.
