MasonReed
Apr 02, 2025Aspirant
Manual update router updates satellites?
I have the RBR750 and two RBS750 satellites. I just performed a manual update on the RBR750 router, by uploading the chk file (7.2.7.15). When it restarted, I opened the two satellite web pages, and ...
Phyber
Apr 02, 2025Apprentice
Typically if you manually update, which is what I do, the satellite(s) are updated first, one at a time, and then the router. Restart the system and you should be good to go. Backup the settings and store them away. If your system works as expected after your update then you're set.
