BrendanKBK
Mar 09, 2025Follower
Marantz AVR nr1710 wont connect to new orbi6
Hi. new user new router installed - Wifi6 0rbi marantz nr1710 wont connect- previous router did no problem (but router was old and dropping out) New router can see the wifi network and accepts th...
Mar 10, 2025Guru - Experienced User
Which Orbi model system do you have?
Is the AVR connecting to the main WLAN or the separate IoT network?
