BrendanKBK
Mar 09, 2025Follower
Marantz AVR nr1710 wont connect to new orbi6
Hi. new user new router installed - Wifi6 0rbi marantz nr1710 wont connect- previous router did no problem (but router was old and dropping out) New router can see the wifi network and accepts th...
Mar 27, 2025Guru - Experienced User
Any progress on this?
BrendanKBK wrote:
Hi. new user
New router can see the wifi network and accepts the password but Spotify wont connect to it.
running on 2.4k
(also wont connect to chromecast possibly)
other devices on the 5k split work fine
any help would be much appreciated
