tansohn
Dec 05, 2024Aspirant
Max number of Satellites for ORBI AX5400
I have a AX5400 router and 5 satellites but i can only get 3 satellites connected at the same time. Is there a way to get all 5 satellites to connect?
tansohn
Thank you, I will try this
CrimpOn
Dec 05, 2024Guru - Experienced User
You may have inferred that a total of six WiFi access points (router and five satellites) is not a typical installation for residential users. These sometimes appear on the forum as a result of buildings with concrete walls which interfere with WiFi signals. If you do get all five satellites connected, it would be helpful to get your perspective on "how well it works".
