bvon
Apr 02, 2023Aspirant
Maximizing Internet Speeds wirelessly with Orbi 6 RBR 760 and Satellites
Hi, I've got an Orbi RBR 760 hooked up via ethernet to a Century Link ONT fiber that's supposed to deliver up to 940 Mbps. I got rid of the Centurylink modem/router so the Orbi is communicating via ...
CrimpOn
Apr 02, 2023Guru - Experienced User
The same device is used to measure speed over WiFi at all three locations?
Internet speed can vary depending on factors outside the local network. It would be useful to record several iterations of the test to look for consistency.
What steps are taken to ensure that the WiFi device is actually connected to the closest WiFi unit for each test?
(I'd suggest deliberately turn off WiFi. Wait two seconds. Then turn WiFi back on again and let it connect.)
(The Orbi Attached Devices web page and Connected Devices information on the Orbi app take much longer to report changes in the network than one might expect.)
The original Orbi had a nice telnet command that would report the actual Link Rate between router and satellites. Alas, the AX models dropped that command (and also dropped telnet - sigh).
