Doc_Eck
May 19, 2020Aspirant
May have uploaded zip file to Orbi
Hello, I recently manually updated my BRB852 router and satellite firmware via the web interface (it was not updating automatically). All went well, but I initially (inadvertently) uploaded the sate...
- May 21, 2020
The Manual Update page is always supposed to look the way it shows in your screenshot. I don't see anything wrong. That page never shows the RBR because the top section's Browse and Update buttons are for the RBR while the bottom section (with the list of checkboxes) is for manually updating any RBSs - You check the RBS you want to update and press the Update button, this takes you to a different webpage to perform the actual update.
For comparison see screenshots I've attached of my Online Update and Manual Update tabs. I have 3 satellies with my RBR. The Online Update tab lists RBR + each RBS, whereas the Manual Update tab only shows the list of RBSs and therefore always has one less rows.
May 19, 2020Guru - Experienced User
Try a different web browser, IE11, FF or Opera.
Be sure to clear ALL browser caches, exit the browser then re-open the browser.
Doc_Eck
May 20, 2020Aspirant
Thanks for the reply. I've tried your suggestion and logged in through Edge (previously Chrome) as well as through Chrome iOS and the update continues to sit there waiting to be applied. If I try to reapply it asks for the file to be reuploaded. At this point /shrug.
- FURRYe38May 20, 2020Guru - Experienced User
Ok, that seems odd.
Well one way to be sure that everything is wiped out is to press the back reset button on the back of the RBR for 15 seconds then release. Setup the RBR from scratch. Clear all browser caches again. During the walk thru of the setup wizard, you may see a prompt or notification of new FW:
There are no actual files for this available yet. So you can apply v3.2.11.2, then check the Orbi app or Auto udpate checker on the RBRs web page to see if this newer version of FW is available to you.
You can choose to update here at this point in the setup wizard or skip and finish the wizard and then go in an manually update FW again.
- Mikey94025May 20, 2020Hero
Doc_Eck wrote:Thanks for the reply. I've tried your suggestion and logged in through Edge (previously Chrome) as well as through Chrome iOS and the update continues to sit there waiting to be applied. If I try to reapply it asks for the file to be reuploaded. At this point /shrug.
Can you upload a screenshot of this? Something is very off if you notice this in different browsers, so there may be something else going on here.
- Doc_EckMay 20, 2020Aspirant
Let me know if you can't view the screen capture. Thanks.
I don't see anything indicating there is a .zip file waiting to be uploaded in your screen shot.
