Doc_Eck
May 19, 2020Aspirant
May have uploaded zip file to Orbi
Hello, I recently manually updated my BRB852 router and satellite firmware via the web interface (it was not updating automatically). All went well, but I initially (inadvertently) uploaded the sate...
- May 21, 2020
The Manual Update page is always supposed to look the way it shows in your screenshot. I don't see anything wrong. That page never shows the RBR because the top section's Browse and Update buttons are for the RBR while the bottom section (with the list of checkboxes) is for manually updating any RBSs - You check the RBS you want to update and press the Update button, this takes you to a different webpage to perform the actual update.
For comparison see screenshots I've attached of my Online Update and Manual Update tabs. I have 3 satellies with my RBR. The Online Update tab lists RBR + each RBS, whereas the Manual Update tab only shows the list of RBSs and therefore always has one less rows.
Mikey94025
May 20, 2020Hero
Doc_Eck wrote:Thanks for the reply. I've tried your suggestion and logged in through Edge (previously Chrome) as well as through Chrome iOS and the update continues to sit there waiting to be applied. If I try to reapply it asks for the file to be reuploaded. At this point /shrug.
Can you upload a screenshot of this? Something is very off if you notice this in different browsers, so there may be something else going on here.
Doc_Eck
May 20, 2020Aspirant
Let me know if you can't view the screen capture. Thanks.
- FURRYe38May 20, 2020Guru - Experienced User
I don't see anything indicating there is a .zip file waiting to be uploaded in your screen shot.
- Doc_EckMay 20, 2020Aspirant
FURRYe38 wrote:I don't see anything indicating there is a .zip file waiting to be uploaded in your screen shot.
I inadvertently selected the zip file when trying to manually update the RBS. Unsure if the zip file uploaded or the actual firmware file was extracted, but either way you can see the firmware waiting to be applied despite having already been done. Any way to remove the update waiting to be applied, which you can see in the attachment?
Thanks.
The attached picture doesn't show any messages. RBS living room and it's version. Nothing else.
Looks ok from the picture.
