Doc_Eck
May 19, 2020Aspirant
May have uploaded zip file to Orbi
Hello, I recently manually updated my BRB852 router and satellite firmware via the web interface (it was not updating automatically). All went well, but I initially (inadvertently) uploaded the sate...
- May 21, 2020
The Manual Update page is always supposed to look the way it shows in your screenshot. I don't see anything wrong. That page never shows the RBR because the top section's Browse and Update buttons are for the RBR while the bottom section (with the list of checkboxes) is for manually updating any RBSs - You check the RBS you want to update and press the Update button, this takes you to a different webpage to perform the actual update.
For comparison see screenshots I've attached of my Online Update and Manual Update tabs. I have 3 satellies with my RBR. The Online Update tab lists RBR + each RBS, whereas the Manual Update tab only shows the list of RBSs and therefore always has one less rows.
Doc_Eck
May 21, 2020Aspirant
FURRYe38 wrote:The attached picture doesn't show any messages. RBS living room and it's version. Nothing else.
Looks ok from the picture.
Thanks Furry; I appreciate the assistance. The RBS living room and it's version continues to be present despite having been updated manually (along with the RBR). Unsure why the RBR is not listed or why the RBR continues to be listed. If all is good I won't worry about it.
Thanks again.
Mikey94025
May 21, 2020Hero
