Duffer10's avatar
Duffer10
Follower
Sep 14, 2024
Mesh and Spectrum
I have a spectrum modem/router combination, and I want to go to the orbi mesh to increase my WiFi coverage. I am not a total geek, but I think I can do this. I have heard that the Spectrum combo might be a problem, and, honestly, I’d prefer something plug and play. I currently have a coax cable from the street to the unit. Can I just connect the node into the current Spectrum unit and somehow disable the router portion of the spectrum, and use the same settings? I’m not sure how many nodes I will need, what is an average length of node placement to maintain speeds. Thank you for your help.
1 Reply
