Parth_Goyal
Jan 28, 2021Aspirant
Mesh Network Connections
I have a gigabit switch connected to my Orbi Main Router which further connects 5 Satellite Nodes, each placed on separate floors. I have multiple devices across my network, so main router might alwa...
Jan 28, 2021Guru - Experienced User
What model Orbi system do you have?
Parth_Goyal wrote:I have a gigabit switch connected to my Orbi Main Router which further connects 5 Satellite Nodes, each placed on separate floors. I have multiple devices across my network, so main router might always stay busy.
Shall I connect my ethernet devices such as TVs, desktops, alexas via a switch to the Satellite of that floor or connect them all directly to the Main Router via a larger switch?
- Parth_GoyalJan 28, 2021Aspirant
I'll be using orbi AX6000. Network traffic management is my prioritization.
Thanks!
- FURRYe38Jan 29, 2021Guru - Experienced User
IF the RBR is going to be the main host router then you can put a larger port switch behind the RBR. I have 24pt behind mine for the main house network. I also hava a smaller 8 port switch that runs a different segment behind my RBR which all of my DISH Hopper and Joey system runs on along with services to the basement RBS and roommate that lives there and with an xbox there.
IF your giong to wired up your RBS to the RBR, reivew this: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
