ericfriar
May 09, 2022Aspirant
Mesh Network with Backhaul
I have the RBS 750 Mesh network with 2 satellites installed. I have backhauled my older Orbi, RBS20 into the 750 router. Everything worked fine for about a year. Now, I have no access to my router ...
May 09, 2022Guru - Experienced User
NG is aware of this. Seems to be working on a fix currently.
Was your FW updated that you know of recently?
Are you try HTTP instead of HTTPS with 192.168.1.1?
What happens if you power OFF the RBR. Disconnect it from the ISP modem, then back ON and try HTTP and 192.168.1.1?
- ericfriarMay 09, 2022Aspirant
I have tried http: https: I have also disconnected everything. Restart the modem, wait for it to fully cycle and begin operation. I then connect the RBS750, apply power, so that it can grab a fresh connection. Then try the 192.168.1.1 and it still refuses connection.
My only other step left is to take my laptop, hardwire connection into one of the ports and see if I can connect that way.
- FURRYe38May 09, 2022Guru - Experienced User
Last resort maybe a factory reset or a 30/30/30 reset on the RBR.
