dalucca2003
Feb 14, 2022Aspirant
Mesh Networking Questions
Couple of questions I have in regards to mesh networking. I have a RBR750 router and two RBS750 satellites. My house is a bit over 3000 square feet. The router is upstairs and the I have one satel...
Feb 14, 2022Guru - Experienced User
I've never worried to much about what order i turn off/shut down devices in.
I've powered off satellites and powered them back on, the router, etc. Never had an issues.
In terms of coverage, you're probably a little overkill if you have 2x satellites. I have a 3200sq ft home and only use 1 satellite.
So you might not see as many devices on the satellites as they can connect to the router fine.
In terms of lot size, thats a harder one as its usually the exterior of homes that blocks signals. Its usually made of materials like cement board, brick, foil lined insulation, metal siding, etc that are great at blocking wifi.
How big is your lot that you're wanting to cover?
- dalucca2003Feb 15, 2022Aspirant
Almost 10,000 feet
