PretzelMan
Dec 08, 2023Aspirant
Mesh Router RBR850 Does NOT show Connected Satellites on Web Display
I hope this is the correct forum.
When I log onto my routers through a browser interface, the connected Satellites do NOT show up.
As can be seen below, I have 4 satellites connected.
CrimpOn
Dec 08, 2023Guru - Experienced User
Has the router been restarted? (Then, wait at least five minutes for things to settle down.)
- PretzelManDec 08, 2023Aspirant
Thank you for the response.
Yes. I have restarted everything multiple times.
On the support call, we also restared and upgraded to the latest firmware.
- CrimpOnDec 08, 2023Guru - Experienced User
(More pointless questions.....)
How are the satellites connected to the router?
- Using the default 5G WiFi backhaul link?
- Using Ethernet cable (i.e. 'wired')?
(If the satellites are 'wired', are they connected directly to the router LAN ports or is there a switch involved?)
What happens if the Orbi is placed in router mode? I understand that when the Internet Service Provider device is itself a router, an Orbi in router mode creates what is called a "Double NAT" that makes specific internet applications much more cumbersome to implement. (not impossible, but a LOT more effort). Plenty of customers have a Double NAT, never know, and suffer no ill effects. I'm just wondering, "what if?"
Everything is connected via WiFi.
When on the phone with support a satellite would not connect, so he had me connect with ethernet.
FYI... This has been working fine for almost a year. This issue just started.
I got cut off with support and will need to call again tomorrow.
- FURRYe38Dec 08, 2023Guru - Experienced User
What browser are you using?
What Firmware version is currently loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the size of your home? Sq Ft?Are the RBS wireless or ethernet connected to the RBR?
Does Orbi app show the 4 RBS as being connected?
Thank you for the response....
As mentioned, I'm using Edge and the firmware is the latest. Support updated all firmware.
My issue is that although satellites are connected to the router, they do NOT show up on the web link.
They show up connected in the app.
I'm thinking I may have a hardware problem as the satellites seem to disconnect.
I will call support again.
