PretzelMan
Dec 08, 2023Aspirant
Mesh Router RBR850 Does NOT show Connected Satellites on Web Display
I hope this is the correct forum.
When I log onto my routers through a browser interface, the connected Satellites do NOT show up.
As can be seen below, I have 4 satellites connected.
Dec 08, 2023Guru - Experienced User
What browser are you using?
What Firmware version is currently loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Are the RBS wireless or ethernet connected to the RBR?
Does Orbi app show the 4 RBS as being connected?
Please edit out any password information seen in pictures prior to posting for security reasons.
PretzelMan
Hello,
I am using Edge.
I have been on the phone with support for 3 hours. He updated to the latest firmware on the router and satellites.
Unfortunately, we got disconnected and I have the same issue....
The satellites are definitely connected and we can see devices connected to them.
If I unplug a satellite, it shows up as a disconnected satellite. When I plug it in, it no longer shows as a satellite, but it is definitely connected.
BTW, my ORBI router is set into AP mode. On the support call, we rebooted the Comcast router as well....
When I get a chance, I will call support back....
