redbeard007
May 14, 2024Aspirant
Microsoft Authenticator times out
Hi all. I have a new fibre connection with an Orbi RBR350 - Router Firmware Version: V4.20.0.4_3.100.71 I use the Microsoft Authenticator app on my Android devices for MFA. When on WiFi throu...
- Jun 04, 2024
Ugh - I have discovered that my ISP has a "Port Filtering" setting that is enabled by default.
"We network block inbound traffic (TCP/UDP) associated with the following ports."
Port
Inbound traffic
0
20
FTP data
21
FTP data
22
SSH (Secure Shell), File transfers
23
Telnet
25
SMTP (email sending)
53
DNS server
67
Bootstrap server, DHCP
68
Bootstrap client, DHCP
80
HTTP server
110
POP3 server
135
remote manage DHCP, DNS server
137
NetBIOS name service
138
NetBIOS Datagram
139
NetBIOS Session
143
IMAP server
161
SNMP
162
SNMP
443
HTTPS server
547
DHCPv6 server
593
HTTP RPC remote procedure
2049
NFS
With this disabled - I can finally use my authenticator app.
Grrrr so frustrating as the ISP never mentioned this!!
May 31, 2024Guru - Experienced User
Is the RBR using auto detected ISP DNS or custom DNS? You might try using some custom DNS like Cloudfare or Quad9. Something I noticed with Apple Beta updates I get, they won't download correctly if I use ISP DNS. They do when I change to custom DNS on my router.
redbeard007
Jun 04, 2024Aspirant
Port | Inbound traffic |
0 |
20 | FTP data |
21 | FTP data |
22 | SSH (Secure Shell), File transfers |
23 | Telnet |
25 | SMTP (email sending) |
53 | DNS server |
67 | Bootstrap server, DHCP |
68 | Bootstrap client, DHCP |
80 | HTTP server |
110 | POP3 server |
135 | remote manage DHCP, DNS server |
137 | NetBIOS name service |
138 | NetBIOS Datagram |
139 | NetBIOS Session |
143 | IMAP server |
161 | SNMP |
162 | SNMP |
443 | HTTPS server |
547 | DHCPv6 server |
593 | HTTP RPC remote procedure |
2049 | NFS |
- FURRYe38Jun 05, 2024Guru - Experienced User
Glad you found the problem. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
