306Orbi
Nov 24, 2021Star
Migrating from RBR50 to RBRE960
Hello Netgear Community... I just ordered my RBR E960 Wifi 6E Orbi Router and Satellite Package and it is due to arrive Friday. I am migrating from Orbi RBR50 to this new Orbi and am very concerned...
Nov 24, 2021Guru - Experienced User
I wouldn't use a backup configuration. Its different hardware.
Your devices should auto-reconnect if you're using the same ssid. Its just the address reservations (if you used them) that you'd need to redo.
lancekelly
Dec 15, 2021Initiate
If it makes you feel any better, I just performed a similar upgrade -- from the RBR850 to the 960. In terms of wireless connectivity, I set my SSID to be the same. It was basically a seamless upgrade -- I did have to upgrade the firmware twice on the 2 Satellites because Satellite 2 was having a problem connecting to Satellite 1 wirelessly. However, everything else went very smoothly. I did not have to reconfigure any of my wireless or wired devices on the network -- and, I have 24 devices total. The speed is blistering fast on the 960 -- you should notice a major difference. Hope this helps. Lance
