VYG
Jul 21, 2021Aspirant
Missing advanced Wifi settings - [RBK352]
Dear all,
I am bit new to Netgear's world so a bit confused, just wonder if advanced Wi-Fi settings such as Mu-Mimo, Fast-Roaming, WMM, etc. should not be accessible by customers?
Looks like I have a bit of compatibility issues with some equipment and wonder if there is any way to play with this options?
Or - this is hoe the systems works and welcome to Netgear's world.
Kind regards,
Those options are not avialble to the user on Orbi AX. They are automatic now.
Try disabling AX mode or try setting CTS values to 2347 if you see 64.
1 Reply
