Jlew04
Oct 26, 2024Aspirant
Missing satellites RBR750
I have 1 RBR750, 3 RBS750, 1 RBR50 and RBS50. Wired - RBR750, 2 RBS750, RBR50 Wireless - RBS750 and RBS50 Inside the house the RBR750 is connected to gateway, 1 RBS 750 connect to wall outlet, an...
Jlew04
Wow .. my layout designer got jacked… but here is one speed test from my phone. The orbi app says the 955 download and 940 upload. While my phone says 199 DL and 74 UL… help please..
Oct 31, 2024Guru - Experienced User
Orbi 50 series is not really supported connected to the 750 series so it may not show up.
If the 3 RBS seen in the Orbi app network map is the 750 series then this is working.
Make sure your phone is connected to the RBR and speed test there. Turn OFF the wifi radio on the mobile device for 5 seconds after you are close to the RBR, then turn it back ON and then speed test at the RBR with Ooklas installable speed test app.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
What mobile device are you using?
Do a speed test with a ethernet connected PC and Ooklas installable speed test app for comparison.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
