zen0701
Feb 20, 2022Aspirant
missing u-boot at flash RBS850 bricked
Model: NETGEAR Orbi satellite RBS850 Any firmware for u-boot for powering up Orbi satellite RBS850? Thanks.
Feb 20, 2022Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
zen0701
Feb 21, 2022Aspirant
Thanks. I've tried the solution you provided but LAN port still unable ping to 192.168.1.1. i think the initial system u-boot (kind of bootloader) didn't work. Please see log file attached.
