will2041's avatar
will2041
Follower
Apr 21, 2021
Mixed backhaul on 850
Hi! I'm looking to answer the same question jkfromk had in https://community.netgear.com/t5/Orbi-AX/Mixed-backhaul-on-ax4200/m-p/1962393
I happily have an RBR850 connected to a satellite using wireless backhaul. I'm wondering if I can use ethernet backhaul to a third satellite.  i.e.:
RBR850 -> (wireless) -> Satellite 1 -> (ethernet) -> Satellite 2
This configuration is not listed in https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System so I wanted to check with the community before buying another satellite.
Thanks!
1 Reply
  • FURRYe38's avatar
    I believe that works. Might search the forums for additional information and posts regarding it.
