jkfromk
Aug 18, 2020Follower
Mixed backhaul on ax4200
Looking to purchase the AX4200 pack from Costco. I need to confirm that I can have the following configuration work: Modem > Orbi Router with wireless connection to Orbi Satellite > Wired con...
Aug 18, 2020Guru - Experienced User
Not sure if that will work, This is the supported wire connected RBS configuration:
