mrp12
Mar 29, 2021Aspirant
Mixed Backhaul on Orbi 750?
I'm having trouble getting a mixed backhaul (wired and wireless) setup working with the Orbi 750. I have been able to do this with an Orbi RBK50 system, and I understand that it should be possible w...
Mar 29, 2021Guru - Experienced User
Mixed works on Orbi AX. It's best to sync the RBS first, then ethernet connect the RBS after wards.
Is the RBS being directly connected to the back of the RBR or is there a LAN switch in between them ?
Also:
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
