Trevmonk
Aug 14, 2024Aspirant
Mixing dual and tri band satellites?
I have had a RBR750 Orbi router for some time and have been using it with three older RBS350 satellites (which are compatible and work). Can I add a RBS750 satellite to this set up? With both dual band and tri band satellites work at the same time with the router? I realise the extra band won't allow the full communication between the old satellites and the new RBS750 but will the RBS750 communicate directly to the router?
1 Reply
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
You can however be aware that v7 FW is not compatible with the RBS350 series. If you want to connect 350 series to the 750 you'll need to downgrade the FW on the RBR750 to v4 along with any other RBS750 series to v4 FW so that the 350 series RBS can work with the 750 series.
