SIndelas
Mar 27, 2021Aspirant
MK83 vs Orbi RBK753
Hi all. I just purchased the Orbi RBK753 two weeks ago(Same price as the MK83 through a deal I got) and have not installed it. I now see there is a new Nighthawk Mesh tri band system. I went through...
Mar 30, 2021Guru - Experienced User
The Orbi AX series from what I was told does NOT support OFDMA.
Been gaming with my Orbi 8 series since 2019. After a year of bugging them about NAT Filter not working right they finally fixed it. Other then that, I have two xbox consoles connected to my system. No complaints.
- SIndelasMar 30, 2021Aspirant
Thanks. I returned mine due to compatablity issue with my ISP's router. My ISP router is very limited in what you can confure. Thus, I did not want to deal with double NAT issues and did not want to run the Orbi in AP mode since I wanted Netgear Armour.
Thanks for your reply
- FURRYe38Mar 30, 2021Guru - Experienced User
Good Luck.
