RobertFoss
May 15, 2022Follower
Model RBR750 Cannot connect a fan that requires a 2.4Ghz connection.
That's it. When I set up my Orbi router it automatically connected to all my Google devices - speakers, doorbell, thermostat but not to my fan. All the Google devices had been connected as 2.4Ghz dev...
Mikey94025
May 16, 2022Hero
RobertFoss wrote:That's it. When I set up my Orbi router it automatically connected to all my Google devices - speakers, doorbell, thermostat but not to my fan. All the Google devices had been connected as 2.4Ghz devices. They are now connected on a 5Ghz band.
The fan requires a 2.4Ghz band and I cannot figure out how to connect it so that I can control it using a Google speaker. It worked fine when I was using the Netgear Nighthawk Model R6700.
So we can best help you, what is the exact make and model of your fan? And how are you trying to connect it to your new Orbi:
- Did you set the same wireless SSID and password on your Nighthawk so you expect everything to reconnect automatically?
- Or, are you now using the fan's app or website to try and connect it manually?
