miketheknight20
Feb 24, 2022Apprentice
Modem -> Router -> EdgeRouter -> Orbi
I have a unique set-up here...I have a Spectrum Modem, connected to a Spectrum Router, then connecting to my Edge Router Lite 3, and a few switches and AP's.
I want to replace the AP's with the RBK753...so what I went from SWITCH to RBK753, went thro the set-up, everything seemed to connect. But after about 2 - 3 minutes BOOM, steady purple light, and all devices show connected with no internet.
What would be the proper set-up for this?
My set-up that I need to keep is Spectrum Modem to Spectrum Router to ERL3 (this is where all work DNS/Firewall rules etc are set-up) and BEHIND the ERL3 I need to add the Orbi
Can you explain the reason to keep the Spectrum router?
If the Edge Router 3 is handling all the DHCP & Firewall rules, then only one port on the Spectrum router can be used, and the goal is not to use the Spectrum router WiFi capabilities. This seems to make the Spectrum router pretty much redundant.
The keys to Orbi products are:
- The RBR750 device must be connected using an ethernet cable to the WAN port.
- RBS devices must be connected to the RBR device either over WiFi backhaul or through the RBR device LAN ports.
It doesn't matter that the RBR750 is in Access Point (AP) mode. It still has to be connected through the WAN port.
If you could make up a simple diagram of how things are connected, that might be useful to the discussion.
- miketheknight20Apprentice
CrimpOn - this is an image of my set-up
Setup
The way Spectrum has things wired (at least for us) is that I HAVE to keep the router in play, even tho it is not doing anything because it has DNS/Gateway etc settings that the Spectrum Modem can ONLY get from that device. Then the ERL3 is assigning DHCP and on a 192.168.5.XXX IP Range.
I want to add the ORBI in behind the ERL3, so that all firewall rules, DNAT etc remain in place and the ERL3 continues to handle DHCP - but I want to use the ORBI to handle WiFi signal/coverage.
Thanks for the excellent drawing. This should work as long as the Orbi RBR750 is connected using the Internet port (yello) and the satellites backhaul to the RBR750 over 5G wireless. It would also work if the RBR750 is connected directly to the EdgeRouter and that 5 port switch is connected to one of the Orbi LAN ports. If you have any intention of using ethernet backhaul for the Orbi satellites, then the Modem -> Orbi -> Switch setup is the way to go. Since the EdgeRouter is handling all the DHCP, firewall, port forwarding, etc. then the Orbi would be put into Access Point (AP) mode using the Orbi web interface.
I still disagree that the Spectrum router is required. Customers receive their public IP, gateway, etc. from Spectrum servers through the modem, not from the router. (As an example, one of the common troubleshooting techniques is to connect a computer directly to the modem. i.e. having no router at all.) I have a Spectrum modem and my Orbi router is connected directly to the Spectrum modem. Having that Spectrum router installed creates a "Double NAT" that will interfere with certain user activities.
https://kb.netgear.com/30186/What-is-Double-NAT
You are faced with a more complicated situation than most customers because the EdgeRouter already exists. The DHCP, firewall, port forwarding,and other features are different than the Orbi equivalents. Using the EdgeRouter rules out using Netgear's Parental Controls and Bitdefender Armor products, as well as OpenDNS on the Orbi.
