tmgrood
Jun 04, 2023Aspirant
Modem to use with RBKE962
Hello, Has anyone got a suggestion on which cable modem to use with the Orbi RBKE962 system? I use Xfinity and would rather buy my own equipment. Thanks
- Jun 05, 2023Hey Furry, thanks.
I should have mentioned it in my original post but I need one that accepts Xfinity voice. I do appreciate your quick response. Thank you!!
Jun 05, 2023Guru - Experienced User
Check to see if NGs CM2000 modem is supported by XF.
tmgrood
Jun 05, 2023Aspirant
Hey Furry, thanks.
- FURRYe38Jun 05, 2023Guru - Experienced User
Ok, the v version will be the one you want then.
Be sure you use a CAT6A STP cable between the modem and RBR.
Enjoy.
