Blueforester's avatar
Blueforester
Motorola or Netgear Modem WiFi Routers with the Orbi Mesh System
Looking to upgrade Xfinity modem WiFi Router and NightHawk R7000 Router.  Will a newer Motorola or Netgear Modem WiFi Router work within an Orbi WiFi Mesh System?  Or will the WiFi signals interfere with one or the other?
  If I decide on the Orbi 850 or 960 series WiFi Mesh, would it be best to just buy a good modem to maximize the performance of the Orbi?  Or buy an equally as good modem WiFi Router to increase coverage and meet the specs of the of the Orbi Mesh System?
Blue
  • michaelkenward's avatar
    michaelkenward
    Think of it the other way round, will the Orbi system work with the new modem/router?
    Should work. If you mean can you connect the Orbi to another modem.
    Why do you want to buy another modem/router? Experienced users would encourage you to go for a modem only device that you can put in front of your Orbi system. Then you have a much bigger choice of routers.
    Putting a router in front of a router is asking for trouble.
    Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
    But that has its drawbacks:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    • Blueforester's avatar
      Blueforester
      Geezz, Just finished a detailed reply and after clicking on "Post" it came up something like could not authenicate?
      Anyway, will try the Cliff Notes version.  My apologies in advance.  I may have not asked the question I was seeking an answer for correctly.
      "Motorola or Netgear Modem WiFi Routers with the Orbi Mesh System"
      Looking to upgrade from Xfinity modem/WiFi unit and Nighthawk R7000.  Will skip details.  Looking hard at Orbi 850 or 860 WiFi Mesh systems.  Need a new modem that will insure I get the maximum performace from the Orbi Mesh system.
      So question I meant to ask is since I'm replacing Xfinity modem/WiFi unit, is it possible or even available, a newer modem/Wifi unit that will work with the Orbi system?  Thinking is, is this an opportunity to extend/improve coverage of the Orbi system with a modem/WiFi unit.
      I ask this as the Xfinity WiFi and R7000 WiFi do not get long.  But if there is a modem/WiFi unit avaiable that will work with the Orbi system, and improve WiFI service, I would like that option.  If not, I just need a good perfomance modem upgrade.   Open to recomendations.
      Thanks.
      Blue
        michaelkenward
        Did this also mean that you could not read the reply to your first message?
        That answers many of the questions in your latest message.
        Why do you want to modem/wifi unit?
        See previous answer.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
      Blueforester
      My Xfinity modem is an Arris XB6. Digging into mine it is a 2018 model refurb.  Gave it to me taped to a piece of cardboard.  Most reviews I found after I got it were not great . Such as:
      Cons
      • Features Intel Puma 7 (bad chipset)
      • Single heat dissipation vent
      • Limited coverage area
      • Expensive
        Yeah, CAT6 is better cable.  But it was not around when I built my house.  And when I added a media room sometime later in the unfunished upstairs space.  So I ran ran CAT5 through out.  And still have plenty left.  In fact I have about a 50' piece laying in the floor by my feet with my crimping tool bag.  I have been running it directly to the modem in what is now my wife's offce to the great so I could get better service and run test off the modem. Dang modem only has two ethnet ports. I have been getting some intermittent errors with internet connection.  Last several days I had planned to test the cable to see if that was the errors.  And probaly go ahead and replce the connectors just to be sure.
        I have not given our internet upgrade project to the boss yet.  But I plan to include the cost to replace all the CAT5 to CAT6 or CAT6e.  She is all about the upgrade because it is interferring with her job.  So going make sure she gets the best!
      Blue
