Nsiddons
Nov 08, 2019Apprentice
Mounting Bracket
So I had to install the RBR850 on the wall. The screw holes on the bottom were perfect. I had to run to Lowes for 2 L bracket looks like garbage but it works. I wonder if Netgear has or had plans for...
Nsiddons
Yes for the 1st gen I order them all the time cause I actually install them for a living. But gen 2 AX I haven seen any yet
ekhalil
Nov 09, 2019Master
I used the old Orbi RBK50 wall mounting brackets to mount the Orbi AX units. Picture attached
The Orbi AX units are a bit bigger in size, but with some "fillers" I managed to re-use the brackets until a kit is available for the new Orbi AX. :) hopefully soon!
