Nsiddons
Nov 08, 2019Apprentice
Mounting Bracket
So I had to install the RBR850 on the wall. The screw holes on the bottom were perfect. I had to run to Lowes for 2 L bracket looks like garbage but it works. I wonder if Netgear has or had plans for...
ekhalil
Nov 09, 2019Master
I used the old Orbi RBK50 wall mounting brackets to mount the Orbi AX units. Picture attached
The Orbi AX units are a bit bigger in size, but with some "fillers" I managed to re-use the brackets until a kit is available for the new Orbi AX. :) hopefully soon!
Nsiddons
Nov 09, 2019Apprentice
I have previously used the 3 links below but was always scared to use the mount you are using but I might try it on my next install. It looks clean
