Nsiddons
Nov 08, 2019Apprentice
Mounting Bracket
So I had to install the RBR850 on the wall. The screw holes on the bottom were perfect. I had to run to Lowes for 2 L bracket looks like garbage but it works. I wonder if Netgear has or had plans for...
ekhalil
Nov 09, 2019Master
I used the old Orbi RBK50 wall mounting brackets to mount the Orbi AX units. Picture attached
The Orbi AX units are a bit bigger in size, but with some "fillers" I managed to re-use the brackets until a kit is available for the new Orbi AX. :) hopefully soon!
Stevensa
Nov 29, 2019Tutor
- ekhalilNov 29, 2019Master
Stevensa wrote:Is this the mount in the picture?Koroao Wall Mount Holder for Orbi Home WiFi
Yes, this is the one in the picture in my previous post.
