Nsiddons
Nov 08, 2019Apprentice
Mounting Bracket
So I had to install the RBR850 on the wall. The screw holes on the bottom were perfect. I had to run to Lowes for 2 L bracket looks like garbage but it works. I wonder if Netgear has or had plans for...
CrimpOn
Nov 30, 2019Guru - Experienced User
Is it correct to assume that you fished the low voltage part of the power cord down and out of the wall?
