grcarter81
Feb 19, 2022Aspirant
Moving Devices to a Different Satelite
The Orbi RBR750 doesn't do a good job of assigning devices to closest satelite, will this ability be added into the app for manual control?
grcarter81
Yes to 30ft apart, 3200 sq ft, 1 router, & 2 satellites.
2.4G & 5G is being used.
Feb 19, 2022Guru - Experienced User
I've got a roughly 3200 sq ft home with just the router and satellite. You might try turning down the broadcast power.
Or test it and see how the speeds do. The devices might be close enough to the router that they're getting better speeds directly connected.
