Imulji
Aug 09, 2021Guide
Moving from RBK23 to RBK753 and having issues!
Hi there Moving from my old RBK23 (1 router and 2 satellites hardwired) system to a new RBK753 ( 1 router and 2 satellites hardwired) system and having massive issues with the move over. I disco...
Aug 09, 2021Guru - Experienced User
Does your modem or ISP use PPPoE or DHCP for connections services? Something to ask the ISP about if you don't know.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed?
Imulji
Aug 09, 2021Guide
Can’t answer the firmware question as I can’t create the network.
Shaw XB6 modem in bridge. DHCP.
Yes One minute off completed.
- FURRYe38Aug 09, 2021Guru - Experienced User
Try using a wired PC and web browser connected at 192.168.1.1 on the RBR and walk thru the setup wizard...
- ImuljiAug 09, 2021GuideI’ll try that tomorrow.
Has anyone experienced this with xb6 bridged? Send unusual that the RBK23 system has no issues.
Would it be helpful to turn off the bridge and try setting up?
The reason I ask is that this is the second RBK753 system I’ve had with the exact same issue. Must be something on my end…- FURRYe38Aug 09, 2021Guru - Experienced User
Possible something between this particular modem and the new RBR system.
You can try the following with the modem as well:
1. Don't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
2. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry resetting the RBR and walking the setup wizard tomorrow and see if it reports anything during the setup and detection of internet.
