swami7774
May 30, 2021Tutor
Moving my Orbi router to another location.
I want to move my Currently my Netgear modem and Orbi RBR850 to another room. Is the process as simple as simply disconnecting and then reconnecting the units or do I have to go through the entire se...
CrimpOn
May 30, 2021Guru - Experienced User
swami7774 wrote:I want to move my Currently my Netgear modem and Orbi RBR850 to another room. Is the process as simple as simply disconnecting and then reconnecting the units or do I have to go through the entire setup process again? TIA.
Assuming the modem is being connected to the same ISP service, just plug them in.
The coax signal at a different location in the house may be different than where the modem is connected now, but there is a pretty wide range of acceptable levels.
