bigfishe
May 03, 2023Aspirant
Multi Building Single ISP FIBER FEED config help
Current Configuration: current barn with living space: 1 GB MIDCO ISP fiber into their HITRON NOV2004 modem, that connects to a current Orbi RBR750 router and a RBS750, adding a new h...
May 03, 2023Guru - Experienced User
Does the 9 series get internet services directly connected behind the ISP modem/ONT?
Recommended configuration should be ISP modem/ONT to Orbi router, 7 or 9 series, then Switches connected behind the RBR and fed out to remote locations.
- CrimpOnMay 03, 2023Guru - Experienced User
Thanks for including the diagram. Alas, the RBR750 router is not shown, which is critical.
Only one router can be connected to the Hitron, and since the primary network is functioning, I assume it is the RBR750.
The RBR750 should be between the Hitron and the switch. Is it?
Congratulations on being able to install fiber between the buildings. (Catt6 Ethernet cable would have worked over this distance as well, but there certainly is nothing wrong with fiber.)
