KingsClass
Sep 22, 2022Aspirant
multi device displayed but only one router and two satellites are connected.
hi everyone, recently on the orbi admin page, I started seeing lots of devices that are offline (like 98 devices ) but on the HOME page, it still shows correctly - Attached Devices (RBS760) R...
michaelkenward
Sep 22, 2022Guru - Experienced User
Router - 1Connected Satellites - 2please let me know if you have any solutions for this. thanks.
What is the problem?
Your router seems to be behaving as designed.
It has remembered devices that were once connected to it. That helps the router to pickup where it left off when these devices try to connect again.
If you don't want to see them, you can clear that list.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manage network access control lists.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
If you have more problems with your RBR760, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
- KingsClassSep 22, 2022Aspirant
thanks for your reply. the problem is, we never had 98 devices connected. we had only 1 router and 2 satellites always and this has been an issue only for the past week or so and not been able to figure out what changed since we didn't do any update on the firmware or anything as such.
