skeelo
Oct 19, 2020Luminary
Multiple Issues: Slow Speed, Network Map Error, Phantom Satellite
Firmware:V3.2.16.6_1.4.4 ISP Modem: Zyxel C3000Z Provider: Century Link 1gbps up/ down fiber Home sq ft: ~6,500 3 satellites and distances: ~30 ft to RBS upper level 1 (wireless backhaul) ~30 ...
- Oct 19, 2020
Whelp, appears to be the switch.
I tested hardwired speeds at the modem and RBR, found both to be near 1gbps. Tested at the switch in an open port and saw speeds drop to 1/3-1/2. Reset the switch and speeds are where they should be at the switch and wall plates.
Looks to have fixed the network mapping issue as well. I am going to leave the phantom satellite in place for now. I do not want to deal with factory resetting everything and setting back up manually and I am concerned a backup file would "reload" the phantom satellite.
Thanks for your help. I should have thought to check at the switch and RBR prior to posting.
Oct 19, 2020Guru - Experienced User
What mode is the modem working in? Router or Modem only?
Are the RBS wired directly connected to the RBR? Or is there a LAN switch in between the RBS and RBR?
IF there is a switch, mfr and model please...
I would review this:
Regarding Phantom RBS:
https://community.netgear.com/t5/Orbi-AX/Phantom-Satellite-On-Phone-App/m-p/1991846#M8484
- skeeloOct 19, 2020Luminary
FURRYe38 wrote:What mode is the modem working in? Router or Modem only?
Router mode.
IF there is a switch, mfr and model please...RBS are connected to RBR using a LAN switch. Araknis AN110SWR24
3-4 nieghbors, all 50-70 ft away.
As mentioned, no issues prior to the system going down this weekend and no changes to the setup since first installed.
Will do, thanks.
- FURRYe38Oct 19, 2020Guru - Experienced User
That's ok. Glad to be a pointer for you.
I recommend non manged non green ethernet switches for use in between the RBR and RBS.
NG GS-105/108v4 series works, D-Links DGS-105/108 and HP Procurve 1400/1800 series also work.- skeeloOct 19, 2020Luminary
I know what non-managed switches are. What is non-green? I have never heard of that before.
