skeelo's avatar
skeelo
Luminary
Oct 19, 2020
Multiple Issues: Slow Speed, Network Map Error, Phantom Satellite
Firmware:V3.2.16.6_1.4.4 ISP Modem: Zyxel C3000Z Provider: Century Link 1gbps up/ down fiber Home sq ft: ~6,500 3 satellites and distances: ~30 ft to RBS upper level 1 (wireless backhaul) ~30 ...
  • skeelo's avatar
    skeelo
    Oct 19, 2020
    Whelp, appears to be the switch.
    I tested hardwired speeds at the modem and RBR, found both to be near 1gbps.  Tested at the switch in an open port and saw speeds drop to 1/3-1/2.  Reset the switch and speeds are where they should be at the switch and wall plates.
    Looks to have fixed the network mapping issue as well.  I am going to leave the phantom satellite in place for now.  I do not want to deal with factory resetting everything and setting back up manually and I am concerned a backup file would "reload" the phantom satellite.
    Thanks for your help.  I should have thought to check at the switch and RBR prior to posting.
