cypressnetwork
Oct 23, 2023Aspirant
Must I plug my new Orbi WiFi 6 Router directly into my modem?
I am installing a Netgear Orbi Triband Mesh 6 System in my home. Do I have to plug the orbi router directly into my modem or can I use a ethernet jack in another room? Thanks
Oct 23, 2023Guru - Experienced User
If the connection is good in the other room from the ISP modem, then you can connect it in the other room.
CAT6A STP cabling is recommended between the ISP modem and RBR router.
A direct connection to any modem or ONT is preferred though.
cypressnetwork
Thank you will start with direct modem first then try connecting to jack one I know all is good.
- FURRYe38Oct 23, 2023Guru - Experienced User
đ
