cw007_hk
Apr 13, 2022Follower
My 2.4GHz appliance cannot be connected after chaging to RBR750
Hi all I upgraded my router from R7000 to RBR750. Afterwards, all my appliance cannot be connected even though I already set exactly the same SSID and password as R7000. I would like to know if there...
KevinLiT
Apr 14, 2022NETGEAR Moderator
HI cw007_hk,
I understand that you are having compatibility issues with your RBR750 and your 2.4 GHz band IoT devices.
- Go to orbilogin.com in a web browser to access the Orbi admin site, Advanced tab, and Advanced / Wireless Settings. Set CTS/RTS Threshold to 2347 for both 2.4Ghz and 5Ghz bands.
- Next, Navigate to the Advanced tab, Setup / Wireless Setup, and uncheck AX Mode for the 2.4Ghz band (only).
- Then add the devices to your RBR750 manually.
Please let me know if this information was helpful!!
Best,
Kevin
Community Team
