sakusa
Apr 30, 2021Tutor
My brand new RBR750 Router and Satellite keeps auto shutting down
Model: NETGEAR AX4200 Orbi WiFi 6 High-Performance Whole Home Mesh(RBR750) Firmware: V3.2.18.1_1.4.14 Orbi app installed on IOS 14.5 (iPhone/iPad) in a duplex apartment This brand new router an...
tak1313
Apr 30, 2021Luminary
So it sounds like it's not "shutting down," ie. turning off, but rather not working in some way, but still "powered up?"
- sakusaApr 30, 2021Tutor
tak1313 i have no way of knowing whether it is "powered up" because none of the lights on either router or satellite are on
- FURRYe38Apr 30, 2021Guru - Experienced User
if swapping the Power adapters around doesn't work and you've tried different outlets, i'd get the system boxed up and return it for another system.
Seems like if there turning off at the same time, possibe power problem with in your home too. Odd behavior for sure.
FURRYe38 tak1313 I just did another review, starting with the satellite.
Both router and satellite have been working fine all day since I rebooted the router this morning.
- The satellite was 'dead' again - the power light is on, but Orbi app can't detect the network from right next to the satellite.
- The router is also 'dead' , with the power light on. However, Orbi app is able to detect the network via 'local network' after a few tries.
Neither unit was showing any of the network strength colors e.g. blue/ magenta
My guess is the system is somehow going into 'sleep' mode when there is no activity.
Is ther any way to prevent that in the Orbi app settings?
