Lucky010
Jan 11, 2023Aspirant
My connected devices loose connectivity with ORBI RBR 850
Hello, I have a an Orbi RBR850 router and one ORBI Satellite connected at my house. Connecting with tablets, phones, laptops or macs etc. and using the wifi works flawless. I do have a list of ...
Jan 11, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
Lucky010
Thank you for the quick answer. I will go through your suggestions over the weekend and post here what I found.
What I did because it was quick were 2 things: 1) I did disable Armor and Traffic Control which did not have any immediate effect 2) I tried to connect to the web-interface of the router whilst being connected to the satellite. I could logon/authenticate to the interface but none of the pages were loading.
i will do more tests over the weekend and post back.
- FURRYe38Jan 12, 2023Guru - Experienced User
What browser are you using? Try different browsers.
Please give feedback to the questions presented.
