nvbeancounter
Jul 18, 2022Aspirant
My guest network had been working fine until recently
I was having the same issue when "enable smart connect" wasn't selected. My guest network had been working fine until recently. I noted that deselecting also resulted in the 5G network not accessi...
Jul 18, 2022Guru - Experienced User
How was the FW updated? Manually or Auto Update?
Has a factory reset and setup from scratch with a wired PC and web browser been performed since last update?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
